Автор Тема: Новая радиостанция от фирмы YAESU "YAESU FT-1D"  (Прочитано 5774 раз)
Фирма YAESU выпустила новую 2-х диапазонную радиостанцию "FT-1D". Встречаем...
http://www.universal-radio.com/catalog/ht/0111.html
The Yaesu FT-1D offers a new level of technology that you can hold in your hand. This 2 meter/440 HT provides both analog and digital communications on both bands with up to 5 watts. Enjoy wideband from 500 kHz to 999 MHz (less cellular frequencies) reception including the AM and FM broadcast band. Solid AM band reception is enhanced with a built-in bar antenna. Other features include: vibrate function, GPS with logging and exchange function, image transmit (QVGA 320 Ч 240), Wires, optional camera microphone, mini-USB port, Micro-SD card port.
144/440 + 500 + 999 МГц, GPS с журналированием и обменом информацией, изображение передается (QVGA 320 Ч 240), Мини USB порт + микро SD карта!!!
Integrated GPS.
CTCSS/DCS Encode & Decode.
Weather Receiving with Weather Alert.
Dot Matrix LCD.
APRS.
Wideband Receive.
http://forums.radioreference.com/amateur-radio-equipment/238995-yaesu-ft1d-c4fm-digital.html
YAESU FT-1D
 Price undecided
 Silver color
 144/430MHz5W
 The end of March or in the shortest
 ■ Compatible with dual communication mode analog / digital
 ■ common with the option VX8G
 ■ APRS function
 ■ featured wide-band receiver
 ■ Built-in AM bar antenna capable of receiving AM / FM
 ■ listening quietly vibrator function, valid at large noise!
 ■ Equipped with GPS logger
 Digital-related
 ■ GSM (group message function)
 Send and receive messages in katakana / up to 80 characters in the alphabet
 of about 0.15 seconds
 ■ Snapshot Snapshot (image data transfer)
 In the display screen of the machine about 20 seconds Handy time display
 can not be sent in digital mode] [FDMA. Set (320 × 240) QVGA size
 ■ Convenient, etc. / clone image data storage backup / the contents of
 memory equipped with a micro SD card slot
 ■ Connecting the camera microphone (terminal MiniUSB) USB data, the
 connection between an external device such as a PC. Useful, for example, a
 firmware update.
 ■ Easy! E20 support (Itsuo / Easy to Operation)
 Redesigned the system operation as easy to use, multi-functional. Enables
 one-touch operation of frequently used functions
 • The one-touch button digital mode in the D
 Wires X corresponding key button key, but also what features a digital
 future
 · GM GSM (group message) key
 ■ E-GPS (GPS data transmission feature easy)
 GPS data can be exchanged easily with fellow ham. One-touch display at the
 same time as the direction and distance of transmission.
 Word from CQ ohm
 Thank you for waiting. I came out feature data!
 The basic dual 144/430MHz digital machine. APRS and broadband reception
 function has been firmly attached.
 Appearance is similar to VX-8G. The options are kind of VX-8G is available.
 Comments about the new features is digital, and then to check the details
 from a little more.
 Price is more, aiming to spread the first "put a price quite strategic! I
 mean "and.
 If price is not much different with the per VX-8D, or will not sell it to explode.
 Still, the details and the software is to be modified.
 Questions or requests to: manufacturer is in the facebook comment at the
 reception.
 Together, we have to tell Mr. manufacturers.
 Please feel free to please.
 Click here for product page
 I tried to summarize it came in FT1D data.
 **From another translated website***
 > FT1D
 > Price undecided
 > Silver color
 > 144/430MHz5W
 > The end of March or in the shortest
 > [Function] Bulletin
 > ■ Compatible with dual communication mode analog / digital
 > ■ common with the option VX8G
 > ■ APRS function
 > ■ featured wide-band receiver
 > ■ Built-in AM bar antenna capable of receiving AM / FM
 > ■ listening quietly vibrator function, valid at large noise!
 > ■ Equipped with GPS logger
 > Digital-related
 > ■ GSM (group message function)
 > Send and receive messages in katakana / up to 80 characters in the alphabet
 > of about 0.15 seconds
 > ■ Snapshot Snapshot (image data transfer)
 > In the display screen of the machine about 20 seconds Handy time display
 > can not be sent in digital mode] [FDMA. Set (320 × 240) QVGA size
 > ■ Convenient, etc. / clone image data storage backup / the contents of
 > memory equipped with a micro SD card slot
 > ■ Connecting the camera microphone (terminal MiniUSB) USB data, the
 > connection between an external device such as a PC. Useful, for example, a
 > firmware update.
 > ■ Easy! E20 support (Itsuo / Easy to Operation)
 > Redesigned the system operation as easy to use, multi-functional. Enables
 > one-touch operation of frequently used functions
 > • The one-touch button digital mode in the D
 > Wires X corresponding key button key, but also what features a digital
 > future
 > · GM GSM (group message) key
 > ■ E-GPS (GPS data transmission feature easy)
 > GPS data can be exchanged easily with fellow ham. One-touch display at the
 > same time as the direction and distance of transmission.
« Последнее редактирование: 14 Мая 2012, 16:54:48 от RAØZHM »
Интересны функции APRS а также Weather Receiving with Weather Alert.
Они в этом плане молодцы, подбивают все под один стандарт. USB шнурок для зарядки + АБ от сотовых телефонов. Если еще мини USB порт окажется кстати, то вообще замечательно для программирования.
А то расплодили шнурков по части перепрошивки, у YAESU одно, у KENWOOD другое, про моторы я вообще молчу.
А так один рзъем и один интерфейс.
Re: Новая радиостанция от фирмы YAESU "YAESU FT-1D"
« Ответ #3 : 03 Августа 2012, 16:21:32 »
Проспект. Вкусно-о-о-о.... :)
« Последнее редактирование: 03 Августа 2012, 16:21:59 от RAØZIJ »
